16 years agoCyclone III Configuration
I have developed a custom board using Cyclone III (EP3C16E144C8) FPGA. I am using JTAG for programming and debugging purpose.
I have attached the schematics for the configuration pins. The problem I am facing currently is that while emulating the singals on Signal TAP II file, I find Reset pin to be always high. I checked the signal using a multimeter and it was low. I am still unable to understand why FPGA is considering the input of reset pin High. Please notify me in case if I have any wrong configuration Thanks3 Replies
gotcha .. i ve to ground the pin instead of leaving it floating
i did it and issue was solved thanks :D - Altera_Forum
Yes, I have grounded all three MSEL[0..3] pins for JTAG configuration.
--- Quote Start --- (6) Do not leave the MSEL pins floating. Connect them to VCCA or GND. These pins support the non-JTAG configuration scheme used in production. Altera recommends connecting the MSEL pins to GND if your device is only using the JTAG configuration. --- Quote End --- although I have also interfaced a EPCS4 in case I need to use Active serial configuration in future. (please refer to schematics attached) can the presence of EPCS4 hardware be an issue ? - Altera_Forum
http://www.altera.com/literature/hb/cyc3/cyclone3_handbook.pdf
Page#171 Cyclone III Device Family Configuration Schemes See if MSEL0,1,2 is correct for configuration mode you want. The Reset pin should be just weak pull-high right?
