16 years agoCyclone III Configuration
I have developed a custom board using Cyclone III (EP3C16E144C8) FPGA. I am using JTAG for programming and debugging purpose. I have attached the schematics for the configuration pins. The ...
16 years agoYes, I have grounded all three MSEL[0..3] pins for JTAG configuration.
--- Quote Start --- (6) Do not leave the MSEL pins floating. Connect them to VCCA or GND. These pins support the non-JTAG configuration scheme used in production. Altera recommends connecting the MSEL pins to GND if your device is only using the JTAG configuration. --- Quote End --- although I have also interfaced a EPCS4 in case I need to use Active serial configuration in future. (please refer to schematics attached) can the presence of EPCS4 hardware be an issue ?
