9 years agoCyclone III and 2xSDRAM
I need to open topic because I couldn't find answers anywhere so maybe someone can help. Card is designed around EP3C40F484C6N with 2 SDRAM chips IS42S16320B-6TL but they are connected on opposite...
9 years agoHi, thank you a LOT for your reply! I m using controller my friend did but we stuck.
What is interesting here is when I run tests on one SDRAM chip it goes even more than 166MHz and behaves stable but problem is to run them together at that freq. Like I mentioned I think that problem is that each SDRAM uses different PLL and that clock traces are also different. Can you point me somewhere to read or what to do, what to investigate first. PLLs are using 7MHz source so since 2 PLLs are generated question is are they in sync, if they are not how to make them? I m talking about clk from FPGA to SDRAM. Next question is about phase shift because I think that each SDRAM for each PLL used needs different shift.
