18 years agoCyclone II: how to delay output to pin?
Is there any way to delay the data output to a pin? I have tried all possible settings in Quartus II and the only way to delay (around 4ns) seems to be to use LCELLs. Also, i'm seeing that an input p...
18 years agoThanks Brad. I will look into your suggestions. I have used a PLL output to phase shift some signals but i have no more PLL outputs available so i'm trying to affect I/O timings by configuring the IOEs. It appears not to work at all. I have used LCELLs in the past but since the timings may change with temperature, chip batch etc it seems unreliable.
How much can the LCELL delay change between chips? I need to achieve some +/- 4ns delay or more so if the LCELL timings change with less than 25% i should be good.
