16 years agoCyclone II glitch on clock
Hi, i have a cyclone II fpga. I'm using two asynchronus clock sources. These clocks are connected into the dedicated clock input of the chip (CLK0 and CLK2). CLK0 is much faster than CLK2 (100MH...
16 years agoSo a workable code example is like this?
PROCESS (CLOCK100)
BEGIN
if rising_edge (clock100) then
clk2_b <= clk2;
clk2_sync <= clk2_b;
end if;
END
PROCESS (CLOCK100, clk2_sync)
BEGIN
if rising_edge(clock100) then
last <= clk2_sync;
if (clk2_sync ='1' and last = '0') then
clk2_enable = '1';
else
clk2_enable = '0';
end if;
end if;
END PROCESS;
STATE_MACHINE: PROCESS (CLOCK100, clk2_enable)
if clk2_enable = '1' then
Thank you
