19 years ago
Cyclone II and DDR pins
Hi
In Cyclone II ep2c5 pinouts document:
http://www.altera.com/literature/dp/cyclone2/ep2c5.pdf
Some pins have additional discription: DQxxx DQSxx DMxx.
Why this DDR signals are assign to this pins? Is that requisite assignment or only recommended? If recommended then why?
PGW
    --- Quote Start ---
    You need to assign DQS/DQ lines to special S/Q pins because the FPGA logic (usually the ALTMEMPHY) needs to adjust the clock phase at the input buffers in order to capture the data correctly. Only S and Q pins have this capability.
    DM lines, which are outputs (and all the other DDR lines for this matter), can be assigned to any pins as far as I am aware.
    --- Quote End ---
    Thanks for response.
    I found information that DQS signals are assign to this pins because this pins are routed directly to the clock control block and global clock bus.
    But I still don't know why DQx (data) and DM (data mask) signals are assign in this way.
    This assignment is not comfortable for me but I don't know whether I can change it.
    Any suggestion will be appreciate.
    PGW
