Cyclone 3 spi interface to mcp2515 spi can chip
HI,
I am trying to write a verilog interface. The interface is between the spi Core and a Mcp2515 Can Controller with a SPI inteface.(just the general interface ). I am not sure about the best way of writing this interface, after obtaining the data sheet for both devices. I think I will have to also use a Sopc Component aswell as the verilog code. Are there any examples of this. Can you start me off with this. Thanks Dave.9 Replies
One thought is to write a small verilog or vhdl module that will drive the SPI lines, and be controlled by a FSM. The data from the Microchip CAN chip would then be placed into data into a small RAM, that would effectively be dual port. Off chip access by an external uC could be done this way, or simply write the logic to interface to SOPC/Qsys.
Fundamentally, if you want to removed the interrupt burden on the processor, doing the design in HDL always seems to be best. -James - Altera_Forum
Hi Rubalho,
- Write a custom SOPC master to control the SPI SOPC component, replacing the logic you have in C. is there a simple way of doin the above,say in verilog. Thanks Dave - Altera_Forum
The SPI component documentation mentions that is is possible to combine it with a DMA component to automate long transfers.
If that doesn't suit your needs, you have two options: - Write a custom SOPC master to control the SPI SOPC component, replacing the logic you have in C. - Write a full-custom SOPC SPI component. - Altera_Forum
Hi Socrates,
Sorry to bother you again. We had a problem, are interface between the spi core and the mcp2525 was driven\writen in C. But it was though that the interface could be hard coded , and relive the burdon from the system c routines. (Less interupts for the c code) I was asked to look into the possibility of hard coding the interface. Thanks Dave - Altera_Forum
You don't need HDL at all. The component has everything required, use Nios and code in C.
Hi Socrates,
If you were using verilog could you give me an example of a read to the Mcp 2515, the format reqd. Many Thanks Dave - Altera_Forum
The component will do the job, You'll only have to tell the component what to do (read or write), select chipselect and assign data buffers to place data.
Thanks Socrates.
I see the Spi component in Sopc. Would you still have to write code to Read/write The Mcp2515 or is that taken care off in the sopc component. The serial control lines so/si and Sck/cs Thanks Dave - Altera_Forum
Just use the SPI component in SOPC/QSys. Very well documented and easy to use.
