15 years agoCyclone 3 (ep3c40f84c7/c8)
cyclone 3 (ep3c40f84c7/c8)
Can You Help, I am using an EP3C40F484C7/C8 Cyclone 3 in an Industrial Control project. The project was written in verilog and includes spI Interfaces, sram , Can etc with SOPC builder nios. the design compiles ok but fails timing analyser checks, slow timingevery time (critical error flagged up).
reqd pulse width =20.2ns high and low
actual min width = 5ns high and low This happens also when I remove all the pin assignments. The Classic analyzer was set to 100 MHz, all timing driven through the PLL When changing speed grade of the device this doesn’t seem to make any Difference to the timing errors. Should I use classic timing analyzer and following the timing optimization advisor? Or use Time Quest, but I am not very familiar with it. Could this verilog code orientated? Could it be the way I use the timiming analyser ? thank you for you help in advance
david
Hi Cris,
I have looked at your reply thanks. In Quartus/clocks I find that my main pll o/p is 100MhZ I have a crystal (on pcb)clock input of 50Mhz An altera reserved Tck of 100MHz We used a de1 pcb first with a cyclone 2 (50Mhz Crystal i/p). I dont know that met slow timing for are application, now we are using a cyclone 3 as mentioned I think the 50Mhz signal is fed into the pll So it doesnt appear that i will establish my timing because of the 50Mhz clock,Could I increase the crystal Mhz to say 100MHZ, but the would't it mess up the pll ? Thanks Again - Altera_Forum
Altera has made classic timing analyzer obsolete. TimeQuest is what they only recommend now. If you only have the sopc system in your design and don't need special constraints on external i/o, migrating to TQ shouldn't be difficult: simply follow instructions in the TQ tutorial.
If you want to keep on with classic analyzer then, yes, the advisor could help a little, at least with setting the correct compilation options. Anyway, IMHO the required pulse width about 20ns means that you have somewhere in the design a 25MHz or 50MHz clock besides your main 100MHz; maybe a generated signal inadvertently used to clock something? Cris
