15 years agoCyclone 3 (ep3c40f84c7/c8)
cyclone 3 (ep3c40f84c7/c8) Can You Help, I am using an EP3C40F484C7/C8 Cyclone 3 in an Industrial Control project. The project was written in verilog and includes spI Interfaces, sram ,...
15 years agoHi Cris,
I have looked at your reply thanks. In Quartus/clocks I find that my main pll o/p is 100MhZ I have a crystal (on pcb)clock input of 50Mhz An altera reserved Tck of 100MHz We used a de1 pcb first with a cyclone 2 (50Mhz Crystal i/p). I dont know that met slow timing for are application, now we are using a cyclone 3 as mentioned I think the 50Mhz signal is fed into the pll So it doesnt appear that i will establish my timing because of the 50Mhz clock,Could I increase the crystal Mhz to say 100MHZ, but the would't it mess up the pll ? Thanks Again
