17 years agoCyclone 3 and Can bus - Possible?
I would like to know if it is possible to build a can bus on my FPGA. I use a Neek II (cyclone 3 starter board : EP3C25F324). This FPGA has no CAN transceiver, but a RS-232 transceiver. Can I connect the RX and TX signals of the can bus to the RX and TX pins of the RS-232 ? I tried with 2.5V (default) in the planner, the compilation is OK, but my CAN analyzer didn't detect any outputs signals. I think the voltage isn't good. Is it possible to change the voltage to have something like : high = from 2.75 to 4V and low= from 0.5 to 2.25V ? I use the "NiosII Advanced CAN IFI" IP to generate the can-bus signals, and the db-9 plug is connected to can-bus analyzer. Thank you for your help. Julie2 Replies
Ok, now I know. Thank you for the quick reply. Julie - Altera_Forum
--- Quote Start --- This FPGA has no CAN transceiver --- Quote End --- But a hardware CAN transceiver is required to interface a CAN bus. Particularly, CAN is a differential bus, so single-ended RS232 can't work.
