Cyclone 10 power-up latches up
Hi PhilipJ,
Do you have any updates that you would like to share with us?
Sadly, nothing helpful.
I tried using the USB blaster but it just couldn't find the JTAG chain in the chip so no further progress.
regards
PhilipJ
- GLees3 years ago
Contributor
The fact that your Blaster can't identify the JTAG chain suggests there's a problem lurking somewhere that needs to be fixed. Whether or not it's related to your "latch-up" problem remains to be seen.
I won't tell you how to do your job, but I will tell you what I would do in your situation. I would first resolve the JTAG situation and see if it has any bearing on your problem. If not, then at least you're in a position to try the USB Blaster and see if you learn anything. Either it does or doesn't help, with or without the check-box, etc. These kinds of problem often take a lot of banging around before they get resolved. It's not a linear process. I'll quote my favorite line from the movie "Twelve Monkeys";
"Science ain't an exact science".
