PhilipJ451
3 years agoCyclone 10 power-up latches up
Hi all, we have a number of designs that use the Cyclone 10CL025YE144 device. They are programmed by a Host CPU using PS mode. Occasionally we run up against a batch of devices that appear to get i...
AqidAyman_Altera
3 years agoHi PhilipJ,
Have you give a try on the workaround suggested by GLees?
PhilipJ451
3 years agoI haven't because I have been rather tied up with other projects.
Also the suggestion of "setting an option in the programming tool..." is confusing.
The programming tool is out Host CPU that programs the chip using the PS method.
However it has prompted me to think, "would these chips also fail to program if I were using a ByteBlaster?" which I will try as soon as I get a bit of time.
Thanks to all for the continuing interest in my problem
regards
PhilipJ
