JLee25
Contributor
3 years agoCyclone 10 LP PLL Numbers
I am using Quartus 19 for new project with 10CL016U256C8G.
I found the device should have 4 PLLs but Quartus said only 2..
Please see attachment.
Which one is correct?
BRs,
Joh...
- 3 years ago
I also tried to compile the design in 19.1 standard version, and it shows 4 Total PLLs. You can refer to the attached screenshot.
AqidAyman_Altera
3 years agoI also tried to compile the design in 19.1 standard version, and it shows 4 Total PLLs. You can refer to the attached screenshot.
- JLee253 years ago
Contributor
Hi Aqid,
Thank you for the share.
I found the root cause as I enable the Migration Devices to smaller chip in the project....
BRs,
Johnson
