JLee25
Contributor
3 years agoCyclone 10 LP PLL Numbers
I am using Quartus 19 for new project with 10CL016U256C8G.
I found the device should have 4 PLLs but Quartus said only 2..
Please see attachment.
Which one is correct?
BRs,
Joh...
- 3 years ago
I also tried to compile the design in 19.1 standard version, and it shows 4 Total PLLs. You can refer to the attached screenshot.
AqidAyman_Altera
3 years agoHi Johnson,
We try to reproduce a working simple design which utilizes 4 PLL on 10CL016U256C8G using Quartus Prime Standard 22.1 version.
It is showing the correct number which is 4 for Total PLLs.
It may be a typo you have seen there. I will report it to the engineering. Can you mention the specific version of Quartus that you use?
Aqid
