Cyclone 10 GX Development Kit factory recovery issue
Hi
To narrow down the issue. Could you provide
1) error result screenshot
Could you also reconfirm again to Set the board switches to the factory default settings.
There is no error message in Quartus while programming .sof to MAX10. Everything seems ok (see the screenshots - pgm_MAX10_sof.png and pgm_MAX10_sof_msg.png). But LEDs on the dev board shows FPGA configured failed (D13 (red) is on) (see the attached pictures). Then when I execute BTS, a popup window shows "FPGA is not detected in the Jtag Chain".
Sometimes the first try fails (see screenshot - pgm_Max10_sof_err_msg.png, error message could be different, e.g., sometimes jtag chain error), but the 2nd try could succeed.
These are all I can observe.
I double checked the board switches are the factory default settings. However, for S3 setting, in the Dev Kit User Guide revision 20171218 (included in the collateral package) says default S3[2:1]=00; in the Dev Kit User Guide revision 20180815, it says default S3[2:1]=01. The physical board comes with S3[2:1]=01. I tried both, the results are the same.
Regard to JTAG TCK setting, I tested with 16M, 6M, 1M. The result are the same.
