Cyclone® 10 GX10GX(10CX085YU484E5G)
Hi
Aqid Ayman
Thank you for your answer.
Because of the browser, I can't reply directly to your reply, I'm very sorry。
Q5: Since I can only test the surface temperature experimentally at the moment, can you tell me how to derive the TJ temperature from the surface temperature? This www has Rjc. TJ=TC+P*Rjc?
A5: Could you define more on what do you mean on the surface temperature? Is it same as junction-to-case temperature?
Q5: I mean the surface temperature is junction-to-case temperature。can you tell me how to derive the TJ temperature from the case temperature? TJ=TC+P*Rjc?
Also,Can you tell me the reason for the large static power consumption of 10GX?
10GX(10CX085YU484)static power consumption is 1W(TA=30℃),
but 10LP(10CL006YU256C6G) is 0.1 w?
THANK YOU !!
- AqidAyman_Altera
As the answer have been provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- AqidAyman_Altera
I afraid that I did not have the answer for it. Maybe you can check with FAE regarding the method to derive the TJ temperature from the case temperature.
As for your second question, as far as I aware, Cyclone 10 LP was built to reduce the power consumption for the user. You can refer more here: Intel® Cyclone® 10 LP FPGA Devices - Intel® FPGA
