XHD
4 years agoCyclone® 10 GX10GX(10CX085YU484E5G)
Hello
I am now using intel 10GX series FPGA (model is 10CX085YU484E5G), I have the following things to ask you,thanks!
1.the FPGA is placed in an iron closed BOX(size L*W*H=260*190*71mm), FPGA wi...
AqidAyman_Altera
4 years agoHi,
I will answer question 1, 2 and 3. Please find the answer below:
A1: We do not expect it to have thermal runaway based on its thermal performance value.
A2: It has heat spreader as part of the package, typically you can use it without heatsink in still air. It is very much depending on ambient temperature of the operating environment and power consumption of the Cycone10GX during operation.
A3: You will need to consult your local FAE regarding the availability of the device.
Aqid Ayman
