11 years agoCYCLON V + DDR3 RAM reset/clock problems within BeMicro CV board
Hello everyone,
I am using the BeMicro CV Development Kit board which is based on a Cyclone V Device 5CEFA2F23C8N. I am using Quartus II 64-Bit Version 13.1.0 Build 162 ( problem also occurs with Version 14.0 ) and I am hanging in 2 problems: 1) sometimes after downloading the elf file: Note: The problem occurs always if an external PLL is used: Verifying 08000000 ( 0%) Verify failed between address 0x8000000 and 0x800D71F Leaving target processor paused 2) Reset problem: the reset does not work at all even though I followed the instructions http://www.altera.com/support/kdb/solutions/rd07072011_71.html The board will be dead if I press the reset button. Enclosed, please find all the referece files. The myload.sh script in the flash directory will load and start the test programm to the BeMicro CV board. I have testet 5 boards already with the same result. Can anyone confirm that there is a problem in the CYCLONE V which is clock/PLL related. If yes, is there a fix available ? or did I make a mistake in my qsys design? Many thanks in advance Reinhard5 Replies
Start with my DDR3 example ...
http://www.alteraforum.com/forum/showthread.php?t=43992 The reset on the Hard IP core does not work correctly --- Quote Start --- Service Request#11062538 Cyclone V DDR3 UniPHY HMC Avalon-MM wait-request lockup after soft-reset The uploaded zip file contains an example design for the BeMicro-CV device. While testing the DDR3 UniPHY controller, it was determined that pulsing soft-reset caused the Avalon-MM interface to lock-up. A Modelsim simulation was created that reproduces the problem, i.e., for some reason the DDR controller forces wait-request to be asserted after the soft-reset signal has been pulsed. The simulation shows that if the global-reset signal is pulsed, the testbench works fine. Altera's Knowledgebase article http://www.altera.com/support/kdb/solutions/rd05212013_358.html has the comments that "Altera strongly recommends using only soft_reset_n at all times. Use global_reset_n only for Power on reset." So, what is wrong with the Cyclone V Hard-memory controller? The file altera_service_request.txt has details on how to synthesize and simulate the design example. --- Quote End --- This has yet to be resolved, but the example I have referred you to works fine. Cheers, Dave - Altera_Forum
Dave, thank you very much for your info but the "bemicro_cv_basic" does not realy help me. I will try to implement the fix from the Altera's Knowledgebase
--- Quote Start --- Dave, thank you very much for your info but the "bemicro_cv_basic" does not realy help me. I will try to implement the fix from the Altera's Knowledgebase --- Quote End --- You didn't scroll down far enough in the other thread. Go all the way to the bottom and download bemicro_cv_examples.zip. Cheers, Dave - Altera_Forum
I followed the instructions from you but the problem still exists.
Enclosed, find the Qsys-file. I also figured out, that there is a CYCLON V PLL bug in the first silicon version and it is also described in the ALTERA Errata Sheet for Cyclone V Devices. http://www.altera.com/literature/es/es_cyclone_v.pdf All my BeMicro CV boards are equipped with known bad CYCLON V silicon. Too bad for me. My question: Is there a solution available and not only a Workaround ? Can I get my BeMicroCV boards replaced from ALTERA? Any Any idea is welcome. Regards, Reinhard - Altera_Forum
--- Quote Start --- All my BeMicro CV boards are equipped with known bad CYCLON V silicon. --- Quote End --- Weird. I ordered several when they first came out from Arrow USA and they have production silicon. I wonder if the European distributors had ES parts. You could contact the distributor and see if they'll replace them ... or give you a discount :) Cheers, Dave
