11 years agoCYCLON V + DDR3 RAM reset/clock problems within BeMicro CV board
Hello everyone, I am using the BeMicro CV Development Kit board which is based on a Cyclone V Device 5CEFA2F23C8N. I am using Quartus II 64-Bit Version 13.1.0 Build 162 ( problem also occurs w...
11 years agoStart with my DDR3 example ...
http://www.alteraforum.com/forum/showthread.php?t=43992 The reset on the Hard IP core does not work correctly --- Quote Start --- Service Request#11062538 Cyclone V DDR3 UniPHY HMC Avalon-MM wait-request lockup after soft-reset The uploaded zip file contains an example design for the BeMicro-CV device. While testing the DDR3 UniPHY controller, it was determined that pulsing soft-reset caused the Avalon-MM interface to lock-up. A Modelsim simulation was created that reproduces the problem, i.e., for some reason the DDR controller forces wait-request to be asserted after the soft-reset signal has been pulsed. The simulation shows that if the global-reset signal is pulsed, the testbench works fine. Altera's Knowledgebase article http://www.altera.com/support/kdb/solutions/rd05212013_358.html has the comments that "Altera strongly recommends using only soft_reset_n at all times. Use global_reset_n only for Power on reset." So, what is wrong with the Cyclone V Hard-memory controller? The file altera_service_request.txt has details on how to synthesize and simulate the design example. --- Quote End --- This has yet to be resolved, but the example I have referred you to works fine. Cheers, Dave
