Cyclon 5 tampering protection bit
If one for example missed the `-eDO_KEY_SECURE` flag and just programmed the key.
Is it possible to just program the tampering bit afterwards?
Yes, you can program the tamper protection bit separately after the key has already been programmed. The `-eDO_KEY_SECURE` switch is what triggers tamper-bit programming during a `.jam` file execution, so if you omitted it the first time, you can re-run the programming command with that switch added.
When programming the design security key with a `.jam` file that has been converted from an Encryption Key Programming file (`.ekp`) that contains the tamper-protection bit programming instruction, add the switch `-eDO_KEY_SECURE` to your programming command if programming of the tamper-protection bit is desired. How do I enable programming of the tamper-protection bit when programming with a .jam file which has been converted from an an .ekp file that contains the tamper-protection bit programming instruction?
So the resolution is straightforward: add the switch `-eDO_KEY_SECURE` to your programming command if programming of the tamper-protection bit is desired.
