Knowledge Base Article
How do I enable programming of the tamper-protection bit when programming with a .jam file which has been converted from an an .ekp file that contains the tamper-protection bit programming instruction?
Description
When programming the design security key with a .jam file that has been converted from an Encryption Key Programming file (.ekp) that contains the tamper-protection bit programming instruction, add the switch -eDO_KEY_SECURE to your programming command if programming of the tamper-protection bit is desired.
Note that the tamper-protection bit is one time programmable and is irreversible.
Resolution
Add the switch -eDO_KEY_SECURE to your programming command if programming of the tamper-protection bit is desired.
Updated 10 months ago
