11 years agocycline ii/ii/iv AS configuration restart with external pin.
Hello all!
Is it possible do a "hardware restart config" with an external pin from epcs serial fash in cyclone 2, 3, 4 ? Normally i must remove a and replace the power for do this..3 Replies
As I recall, there is a pin on Altera FPGAs that external hardware can use to cause the FPGA to reconfigure. Check the configuration handbook for details.
You can assert (and then deassert) the nCONFIG pin to initiate reconfiguration. You can also issue a JTAG instruction to initiate reconfiguration.
Both of these solutions require some form of connection to the board, so your "solution" depends on what you have available. Cheers, Dave - Altera_Forum
thank you all for the answers..
I read the documentation that talks about the pin nconfig..
