AFies
4 years agoCvP with Arria 10 - Enforce factory fallback or alternative access to flash
I'm using an 10AX115N2F4 FPGA with CvP. We have a flash section at the start containing the factory image which can be used to write the flash, plus the section containing the periphery imag...
YuanLi_S_Intel
4 years agoWe cannot know whether if the core image is correct for the peripheral image. But however, you can check the CVP status register (Page 24) for any core logic configuration error.
The current driver flow provided in Arria 10 CVP user guide (Page 21), doesn't have the default factory image. If your application need it, you may create own driver with that.
Arria 10 CVP User Guide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_cvp_prop.pdf
