17 years agocustom instructions implementation
Hi everybody, I'm trying to implement a mac unit as custom instruction into the Nios2 to multiply 2 operands and add another. I had no problems describing it in vhdl. Unfortunately I'm stuck n...
17 years agoStefaan,
thank you for your reply. I haven't been at home over the weekend so that I wasn't able to write here. My vhdl code isn't that complex to explain the ide's behaviour. I'll show you: --- Quote Start --- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library WORK; entity mac is Port ( A : in STD_LOGIC_VECTOR(15 downto 0); B : in STD_LOGIC_VECTOR(15 downto 0); C : in STD_LOGIC_VECTOR(31 downto 0); Q : out STD_LOGIC_VECTOR(31 downto 0); clk : in STD_LOGIC); end mac; architecture Behavioral of mac is signal Qs : STD_LOGIC_VECTOR(31 downto 0); begin MAC : Process (CLK) Begin If CLK'event and CLK = '1' Then Qs <= A*B; End If; End Process; Q <= Qs + C; end Behavioral; --- Quote End --- I guess I'll just try around a little. Maybe I'm lucky to find sth. Thanks anyway again for the help. Cheers, Dash
