17 years agocustom instructions implementation
Hi everybody, I'm trying to implement a mac unit as custom instruction into the Nios2 to multiply 2 operands and add another. I had no problems describing it in vhdl. Unfortunately I'm stuck n...
17 years agoDash,
1. I don't know 2. Maybe related to your VHDL description. If it is not a big secret post it, or send me a message. 3. The compiler itself will never use your custom instructions to optimise code. Because the compiler is not build with this information. You have to change and rebuild the compiler for that (what you propably don't want to do). The only code that will use the custom instruction is if you call the macro. (there is an exception for flating point instructions, where altera build support for it into the compiler, it is however a job for specialists to do that). Stefaan
