16 years agoCustom component attempt, but it doesnt work
Hi try create simply custom component. In the pdf altera avalon specification is described MM slave. I wrote this vhdl(very simply, i try learn add component):
entity MyCustom is port ( clk : in std_logic; wr : in std_logic; write_data : in std_logic_vector(7 downto 0); reset : in std_logic; -- conduit led: out std_logic_vector(7 downto 0) ); end MyCustom; architecture pokus of MyCustom is begin process(clk,reset) begin if (reset='0') then led<="00000000"; elsif(clk = '1' and clk'event)then if(wr = '1')then led <= write_data; else null; end if; end if; end process; end pokus; signal from entity are the same like on example in the pdf. i wanna only write values to output. C code is this: # include <stdio.h> # include <system.h> # include <io.h> int main() { IOWR(0x00011018,0,0x0f); //0x00011018 this the base address of my component from SOPC return 0; } But it doesnt work, is that wrong way? Thanks, VaclavNo RepliesBe the first to reply
