17 years agoCROSS CLOCK vhdl
Hello Everybody, In my application I receive images from a camera that uses CAMERA LINK protocol (100 fps). The camera generates its own 40 MHz pixel clock. All the data's from the camera ...
17 years agoHello,
It means that for cross clock the data I should use the FIFO, and to cross clock domain the signal LVAL, FVAL and DVAL I should use 2-ff stage synchronizer? Can I mix the 2 techniques?:confused: ---------------------------------------------------------- clk domain 1 // >>---------------------->>// clock domain 2 ----------------------------------------------------------- data[9:0] ----------->> fifo ------------>> data_sync[9:0] FVAL --------------->> 2-ff sync------->> FVAL_sync DVAL --------------->> 2-ff sync------->> DVAL_sync LVAL --------------->> 2-ff sync------->> LVAL_sync fval=frame valid dval=data valid lval=line valid Thank you, DABG
