17 years agoCROSS CLOCK vhdl
Hello Everybody, In my application I receive images from a camera that uses CAMERA LINK protocol (100 fps). The camera generates its own 40 MHz pixel clock. All the data's from the camera ...
17 years agoHello,
Thank you KAZ and JACK, Yes, the 2nd option that explains Jake is the easiest, however the problem is that I am using a Cyclone 2, and the CLK_40MHz that comes from the camera is not phisically connected to a dedicated CLK pins. (We designed the board, and we did not take it not account, ups:o) "only dedicated CLK pins on the FPGA can be connected to clock input ports of PLLs" Cyclone 2 manual. And I got this error after compiling: "Port type INCLK of the PLL is assigned to a location which is not connected to port type INCLK of any PLL on the device". I guess I will try to develop the option that use the FIFO. I need to work at 160MHz because then I am going to store the last 20 lines of the image in the internal memory (m4k), and I need to read 4 random pixels to implement a Bilinear Interpolation. Still I am confused with the two flip flop stage synchronizer, in which cases are them useful? Thank you.
