14 years ago
create_generated_clock
Altera supports "create_generated_clock" constraints. I have few questions.
1. Does Altera supports gated clock conversion (like Synplify Pro)
2. If supports, what is the use of 'create_generated_clock' constrain.
Because after GCC, all flops will be connected to the master clock.
Please help me to understand.
freak
    Well, I just tried it and it worked.
    - Using Timequest: http://quartushelp.altera.com/current/mergedprojects/logicops/logicops/def_synth_gated_clock_conversion.htm
    - Following Altera's clock gating guidelines: http://quartushelp.altera.com/9.1/mergedprojects/verify/da/comp_file_rules_clock.htm
    The code:
    -- Verilog
    module p1 (clk, enable, rx, tx);
    parameter MY_WIDTH = 2;
    input wire clk;
    input wire enable;
    input wire [MY_WIDTH-1:0] rx;
    output wire [MY_WIDTH-1:0] tx;
    wire clk2;
    clockGate cg(enable, clk, clk2);
    reg [MY_WIDTH-1:0] r;
    always @ (posedge clk2) begin
    r <= rx;
    end
    assign tx = r;
    endmodule
    module clockGate(
    input wire enable,
    input wire clkIn,
    output wire clkOut
    reg q;
    always @ (negedge clkIn) begin
    q <= enable;
    end
    assign clkOut = q & clkIn;
    endmodule
    -- SDC
    create_clock -name clk -period 10 [get_ports clk]
    No, I never used it. I just prefer to always use clock enable style.
    ASIC tools seem more consistent at converting clock enables to clock gating than otherwise arround too.
    I have some faint recollection of someone managing to get it to work, but you need your clock gates to meet a supported template.
    rbugalho: i remember playing with this feature in Quartus, and it didn't work how i wanted it to. have you? then again i haven't used Synplify
    Quartus has an option to convert gated clocks to clock enables.
    create_generated_clock constrains are used when
    a) you use logic to divide a clock's frequency
    b) you use a PLL do derive a clock (although the derive_pll_clocks command does it automatically for you)
    c) you need to constrain a source synchronous interface (ie, you need to create a derived clock at the pin)
    d) ... probably a bunch of other situations
