14 years agocreate_generated_clock
Hi, Altera supports "create_generated_clock" constraints. I have few questions. 1. Does Altera supports gated clock conversion (like Synplify Pro) 2. If supports, what is the use of 'cre...
14 years agoWell, I just tried it and it worked.
- Using Timequest: http://quartushelp.altera.com/current/mergedprojects/logicops/logicops/def_synth_gated_clock_conversion.htm - Following Altera's clock gating guidelines: http://quartushelp.altera.com/9.1/mergedprojects/verify/da/comp_file_rules_clock.htm The code: -- Verilog module p1 (clk, enable, rx, tx); parameter MY_WIDTH = 2; input wire clk; input wire enable; input wire [MY_WIDTH-1:0] rx; output wire [MY_WIDTH-1:0] tx; wire clk2; clockGate cg(enable, clk, clk2); reg [MY_WIDTH-1:0] r; always @ (posedge clk2) begin r <= rx; end assign tx = r; endmodule module clockGate( input wire enable, input wire clkIn, output wire clkOut ); reg q; always @ (negedge clkIn) begin q <= enable; end assign clkOut = q & clkIn; endmodule -- SDC create_clock -name clk -period 10 [get_ports clk]
