14 years agocreate_generated_clock
Hi, Altera supports "create_generated_clock" constraints. I have few questions. 1. Does Altera supports gated clock conversion (like Synplify Pro) 2. If supports, what is the use of 'cre...
14 years agoQuartus has an option to convert gated clocks to clock enables.
create_generated_clock constrains are used when a) you use logic to divide a clock's frequency b) you use a PLL do derive a clock (although the derive_pll_clocks command does it automatically for you) c) you need to constrain a source synchronous interface (ie, you need to create a derived clock at the pin) d) ... probably a bunch of other situations
