11 years ago
CPRI on stratix IV GT board
I'm trying to use CPRI IP core on a stratix IV GT board.Actually the supported device familys from the user guide do not include stratix IV GT. However, the similar stratix IV GX is included. but when I set the project device as stratix IV GT, I can generate CPRI core. Then I tried to set the project device as Max10, which absolutely does not support this IP core,I can't generate as I expected. The only problem is that I can't simulate my design under GT. So I only verified simulatoin under GX. When I tested my design on real board, I found that although the Interface response signal "waitrequeset" is functional, the CPRI CPU interface can not be read or written.And other CPRI functions like reset, 8b/10b ,RX status display are right. Now I just want to know whether the cpri core supports stratix iv gt.
One kind of warning that may matters is :
"Synthesized away the following RAM node"……
note that I got almost the same warning,and exact the same critical warning when I set the device as GX during compilation.
Here I attach the warnings during the compiling.
Thanks in advance!
    Dear Sam Lee,
    I am glad to see your request on forums.
    We also have the same boards stratix IV GT, and also planning to work on CPRI.
    Did you receive any reply from Altera support team?
    Could you please suggest me how can I proceed to start the CPRI design on Stratix IV GT, if possible.
    Thanks a lot.
    Thanks and Regards,
    Koteswararao Kondepu
    I got reply form Altera feedback, it seems that the GT device just can not use this CPRI core although some low level functions are good.Is that a kind business strategy or do having technical problems?:cool:
    Here is the mail:
    Dear Sir:
    Your query on the Altera SW Depot has been redirected to the Altera technical documentation team.
    The CPRI MegaCore Function User Guide states that the CPRI IP core does not support Stratix IV GT devices: the Device Support table clearly states that the IP core provides Stratix IV device family support only for Stratix IV GX devices. However, as you found, the Quartus II software does not prevent you from generating an IP core variation that targets such a device.
    The technical documentation team is not equipped to provide technical support. For further assistance, we recommend that you file a support request at myAltera.
    Liz
