arik
7 months agoCPRI F-Tile Dynamic Reconfiguration
Hi, I use the Q24.2 and have Agilex7 F-Series 014. I my design I use CPRI Phy over several of my FGTs. I generated the CPRI Phy IP to have 4 line rates (LRs) - LR8 (startup profile), LR7, LR5 & LR...
arik
6 months agoHi,
Thank you for your response.
I did not create a simulation for the design, I work only with the Signal Tap.
When I mentioned that the recovery wasn't successful meant that for example, if the startup LR is LR8 and the transceiver was in LR7, if I set the Recovery command to startup LR, I will expect that the transceiver will start to receive and transmit in LR8. However, all I receive is "garbage" in the rx_data in LR8.
What is wrong with my process that was described in my previous message?
CheepinC_altera
6 months agoHi Arik,
Just would like to follow up with you on my previous note. Please let me know if there is any concern. Thank you.
