15 years agoCPLD EPM240T Serious Burn down!!
Hi,I met a very bad problem when I use CPLD EPM240T.
(1) Environment : in this project,it have 10 IO board with EPM240T,all these board connected through one back board.Between these EPM240T,there is one sigle connection without any RESISTOR,this sigle connection is used EPM240T PIN-77,and all EPM240T PIN-77 are set as input. (2)Problem:when insert these IO board into back board,EPM240T will burn down after power-on delay,not all EPM240T will burn down,but at least two nearby,sometimes 3 or 4,the rest board are work well.After burn down,there is short circuit in EPM240T between VCC and GND.It's confuse that this problem is not happen everytime,and cannot reappear. (3)Question:There are at least two board burn down nearby shows that should be something cause this problem with connection between these EPM240T.All connected pin are set as input,is this a reason cause the burn down problem??Why this problem happen?Is there any one meet this problem?Could anyone help me?
