15 years agoCPLD EPM240T Serious Burn down!!
Hi,I met a very bad problem when I use CPLD EPM240T. (1) Environment : in this project,it have 10 IO board with EPM240T,all these board connected through one back board.Between these EPM240T,t...
15 years ago --- Quote Start --- there is a surge at poweron --- Quote End --- Overvoltage had been also my assumption. Basically, the bad performing power supply should be replaced by something reliable. It's not easy to limit the supply voltage at the board level. A 3.3V TVS diode won't considerably reduce the overvoltage because it's characteristic is too soft. A thyristor crowbar circuit could act more effectively but needs supply disconnect, if trigerred. And it possibly causes more harm with a badly designed power distribution system.
