16 years agoCounterfeit Device? EP3C16Q240C8
I started ringing out the pins on our EP3C16Q240C8 we bought through a broker since they are not programming/coming out of reset.
Starting with pin 8 on a virgin device, I'm ringing out the ground pins under a microscope. I haven't rung EVERY ground pin, but so far I have seen that some do not connect to others. Pin 8 rings to: 16, 172, 67, 125, 193 Pin 8 DOES NOT ring to: 11, 62, 116, 130, 191 Does this make sense so far? I though GND would be GND inside the entire device.2 Replies
--- Quote Start --- $$$$$$$$$$$$$$$$$$$$$$$ Duh, found the problem - schematic was a copy & paste from an old Cyclone design which had the VCCA pins tied at 1.2V. Will change to 2.5V. --- Quote End --- >>>>>>>>>>>>>>>>>>>>>>>>> Added 2.5V, Master and Slave Active Serial devices now working. - Altera_Forum
--- Quote Start --- I started ringing out the pins on our EP3C16Q240C8 we bought through a broker since they are not programming/coming out of reset. Starting with pin 8 on a virgin device, I'm ringing out the ground pins under a microscope. I haven't rung EVERY ground pin, but so far I have seen that some do not connect to others. Pin 8 rings to: 16, 172, 67, 125, 193 Pin 8 DOES NOT ring to: 11, 62, 116, 130, 191 Does this make sense so far? I though GND would be GND inside the entire device. --- Quote End --- $$$$$$$$$$$$$$$$$$$$$$$ Duh, found the problem - schematic was a copy & paste from an old Cyclone design which had the VCCA pins tied at 1.2V. Will change to 2.5V.
