17 years agoCould you provide a easy way to master TimeQuest?
The documents are not easy to understand many concepts, so could you provide a easy way to master TimeQuest?
For example, provide more design examples, how to set contrains, and how to deal with the slack problems?2 Replies
If your company will spot for it, I would highly recommend the timequest class from altera. It helped me a lot when I was first starting out with Altera. However they happen only every couple of months. Other than that start first with constraining just clocks and using derive_pll_clocks . IO constraints still confuse me a little at times.
I have been suffering through the Altera TQ documentation myself this week and it is not very clear. I have, however, found a document that was posted by Graham in the "Constraining SOPC Builder designs using TimeQuest" thread that explains using TQ for basic assignments much better than the Altera Docs. Here is a link to it: http://www.alteraforum.com/forum/attachment.php?attachmentid=574&d=1219074045 I am still not 100% sure on all aspects, but it was fairly useful to me. Regards, Niki
