14 years agoCould some one explain some thing in this schematic please :)
Im very new to FPGA's and am using this attached schematic to crib from.
every thing makes sense apart from the following FPGA pins pins 26,81 held high to 1.2v pins 27,80 held to ground why are these 'random' pins held high and to ground like this? would the FPGA function as normal if they where just left unused? Thanks :)28 Replies
--- Quote Start --- Iv got a little bit lost, so i do need these pins now? --- Quote End --- It depends on what devices you want to load on your board. If you want to load either the EP2C5 or EP2C8 device on your board, then you need to have these extra power-pin option resistors. --- Quote Start --- where in the documentation should i be looking to gather this information for my self for future projects using different FPGA's :) --- Quote End --- In the pinout files I linked to. You should also synthesize a design with Quartus and then compare the .pin file it generates with the pins in your schematic to confirm you have every pin correct. Cheers, Dave - Altera_Forum
where in the documentation should i be looking to gather this information for my self for future projects using different FPGA's :) thanks :) - Altera_Forum
--- Quote Start --- If I was reviewing that schematic, my review comment would be that this comment be improved, eg., put a dashed box around both resistors and change the note to 'Power connections on EP2C8'. --- Quote End --- Right. It's not good that you need to review the pinout file to be sure about the purpose of this connections. - Altera_Forum
Hey Frank,
--- Quote Start --- As the text EP2C8 near the jumper already suggests, these pins have to be connected to GND and VCCINT when migrating to EP2C8. --- Quote End --- I didn't even see that text in the schematic. Thanks for spotting it :) If I was reviewing that schematic, my review comment would be that this comment be improved, eg., put a dashed box around both resistors and change the note to 'Power connections on EP2C8'. Cheers, Dave - Altera_Forum
--- Quote Start --- There is no reason for these signals to be pulled to ground or any other voltage. The pull-up to 1.2V is wrong, since 1.2V is not a valid logic level for a 3.3V I/O. --- Quote End --- The pinout file clarifies the point. As the text EP2C8 near the jumper already suggests, these pins have to be connected to GND and VCCINT when migrating to EP2C8. In so far, it's strictly required to connect them this way. The unusual point is to use jumpers in this place. Usually the migration pins would be connected directly to the power planes without jumpers if the design is prepared for the migration device. Regards, Frank - Altera_Forum
ah LVDS pairs
I have never come across these before. just did a bit of research on them and they make sense :) (not needed in my design though :)) thanks for all your help :) - Altera_Forum
--- Quote Start --- every thing makes sense apart from the following FPGA pins pins 26,81 held high to 1.2v pins 27,80 held to ground why are these 'random' pins held high and to ground like this? --- Quote End --- When you are designing with FPGAs, there are a few documents you need to refer to. First is the handbook for the device: http://www.altera.com/literature/lit-cyc2.jsp On this page there is a link to the device pin outs: http://www.altera.com/literature/lit-dp.jsp?category=cyc%20ii&showspreadsheet=y If you look at the PDF for the device in the schematic: http://www.altera.com/literature/dp/cyclone2/ep2c5.pdf It tells you that pin 26+27 on the T144 page are either IO or an LVDS pair, and the same goes for 80+81. If the design was planning on using LVDS, then Bank 1's VCCIO would need to be 2.5V. The schematic shows it as 3.3V. There is no reason for these signals to be pulled to ground or any other voltage. The pull-up to 1.2V is wrong, since 1.2V is not a valid logic level for a 3.3V I/O. --- Quote Start --- would the FPGA function as normal if they where just left unused? --- Quote End --- Yes. Cheers, Dave - Altera_Forum
I might be mistaken but it seems like those pins correspond to differential pairs (see lvds (http://en.wikipedia.org/wiki/low-voltage_differential_signaling)) where one is high and another one is low.
