14 years agoCould some one explain some thing in this schematic please :)
Im very new to FPGA's and am using this attached schematic to crib from. every thing makes sense apart from the following FPGA pins pins 26,81 held high to 1.2v pins 27,80 held to ground ...
14 years ago --- Quote Start --- Iv got a little bit lost, so i do need these pins now? --- Quote End --- It depends on what devices you want to load on your board. If you want to load either the EP2C5 or EP2C8 device on your board, then you need to have these extra power-pin option resistors. --- Quote Start --- where in the documentation should i be looking to gather this information for my self for future projects using different FPGA's :) --- Quote End --- In the pinout files I linked to. You should also synthesize a design with Quartus and then compare the .pin file it generates with the pins in your schematic to confirm you have every pin correct. Cheers, Dave
