AnkitaBhat
3 years agoCould not detect PAC Arria 10 Gx using command lspci
I am trying to connect PAC Arria 10 Gx to Fujitsu mainboard D3433-S. The OS is not recognizing the connection on PCIe slot. The command lspci | grep 09c4 gives no output.
Could you plea...
JohnT_Altera
3 years agoHi,
May I know if you have power up the Arria 10 PAC correctly? Do you follow the guide in https://www.intel.com/content/www/us/en/docs/programmable/683633/1-2-1/installing-the-card-in-the-host-machine.html
