16 years agoCorrect use of reset input of a FF. VHDL
In my design I will process an image. In part of my hardware I need to RESET some FLIP FLOPS when FVAL(frame valid) arrives. Is bad if I use the signal FVAL directly connected to the reset input of the Flip FLop? Please look the attached file. If I give reset directly with the FVAL, it will use less resources, but I do not know if it is bad. Or the reset must be always connected to the global reset. Sorry for the dummy question. Thanks.2 Replies
Selecting between async or sync reset is not a trivial issue.
You need async reset at power-up, or when you have no clock yet, or when you can't afford the pipeline cycle (sync reset would reset the flip-flop in the next cycle, async would reset on "this" one). In either case you should synchronize the reset signal to the flip-flop clock. - Altera_Forum
It's safer to use a synchronous reset instead of an asynchronous one like you are proposing. if FVAL signal is glitch free, it could work, however, i guess FVAL is synchronous to master clock and is preferable adding a synchronous reset signal to your hardware.
