13 years agoconver froms td_logic_vector to integer
hai every one i'm new to vhdl code and i got problem how to use decimal value instead of binary
for example right_m<="1010001010"; left_m <="1011101110"; i want to convert it to right_m<=650 left_m <=750 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity adel is Port ( clock,rest : in STD_LOGIC; input : in STD_LOGIC_VECTOR (4 downto 0); left_p : out std_logic; right_p : out std_logic); end adel; architecture Behavioral of adel is type state is (forward,right60,left60); signal pr_state,nx_state : state; signal counter : std_logic_vector(9 downto 0) ; signal left_m : std_logic_vector(9 downto 0) ; signal right_m : std_logic_vector(9 downto 0) ; begin process(clock,rest) begin if(rest='1' ) then counter<="0000000000"; right_p <= '0'; left_p<= '0'; elsif (rising_edge (clock))then if(counter=800) then counter<="0000000000"; else counter<=counter+'1'; if(counter<right_m) then right_p<='1'; else right_p<='0'; end if; if(counter<left_m) then left_p<='1'; else left_p<='0'; end if; end if; end if; end process process(clock,rest) begin if(rest = '1')then pr_state <= forward; elsif(clock'event and clock ='1')then pr_state <= nx_state; end if; end process; process(pr_state,sensor_input) begin case pr_state is ----------------------forward---------------------------- when forward => if(input = "11000")then nx_state <= right60; right_m<= "1010001010"; left_m <= "1011101110";9 Replies
thenx every one for helping me
any one has a good and easy reference to understand vhdl coding thanx alot - Altera_Forum
thanx alot
--- Quote Start --- Don't use library std_logic_arith. It's a bad practice of vhdl. use instead numeric_std: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; signal left_m : unsigned(9 downto 0) ; signal right_m : unsigned(9 downto 0) ; right_m<=to_unsigned(650, 10); left_m <=to_unsigned(750, 10); You cast the numbers to unsigned. The first parameter is the number and the second the bits amount. --- Quote End --- thanx alot for ur help do u hv any good reference for vhdl becz i want to improve my self in coding - Altera_Forum
--- Quote Start --- Don't use library std_logic_arith. It's a bad practice of vhdl. use instead numeric_std: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; signal left_m : unsigned(9 downto 0) ; signal right_m : unsigned(9 downto 0) ; right_m<=to_unsigned(650, 10); left_m <=to_unsigned(750, 10); You cast the numbers to unsigned. The first parameter is the number and the second the bits amount. --- Quote End --- It could be easily converted to std_logic vector: right_m<= std_logic_vector(to_unsigned(650, 10)); left_m <= std_logic_vector(to_unsigned(750, 10)); - Altera_Forum
In addition to what others have said - if you have a std_logic_vector that is storing an integer, why are you using a std_logic_Vector at all? why not just use an integer? (unless its the top level).
--- Quote Start --- you can also try: right_m<=conv_std_logic_vector(650,10); left_m <=conv_std_logic_vector(750,10); --- Quote End --- But this is considered bad practise, as it requires the library ieee.std_logic_unsigned. This library should really be avoided, as it can cause confusion and problems when trying to use a bit more arithmetic. - Altera_Forum
--- Quote Start --- you can also try: right_m<=conv_std_logic_vector(650,10); left_m <=conv_std_logic_vector(750,10); --- Quote End --- If you use the vhdl 2008 compiler option in Quartus, then you can use the constructs: right_m <= 10D"650"; left_m <= 10D"750"; In addition, you will want to use ieee.numeric_std.all as the previous post suggested. Best, James - Altera_Forum
you can also try:
right_m<=conv_std_logic_vector(650,10); left_m <=conv_std_logic_vector(750,10); - Altera_Forum
