13 years agoconver froms td_logic_vector to integer
hai every one i'm new to vhdl code and i got problem how to use decimal value instead of binary for example right_m<="1010001010"; left_m <="1011101110"; i want to conver...
13 years ago --- Quote Start --- you can also try: right_m<=conv_std_logic_vector(650,10); left_m <=conv_std_logic_vector(750,10); --- Quote End --- If you use the vhdl 2008 compiler option in Quartus, then you can use the constructs: right_m <= 10D"650"; left_m <= 10D"750"; In addition, you will want to use ieee.numeric_std.all as the previous post suggested. Best, James
