10 years agoConstrainst for data launched by negative edge
Hi, What is the correct way to constrains source synchronous inputs in this case:External device provides clock with data. External device launches data on falling edge. FPGA latches dat...
10 years agoHi,
Thanks for reply kaz. So as I understand you are saying that multicycle is not needed in my case, since data is sampled at same clock period? What do you mean by saying: --- Quote Start --- You can either enter offset directly relative to falling edge as you did or modify it relative to latch edge at fpga pin --- Quote End --- . How it can be modified? So what to do next? Clock relationship seems to be correct by looking at TimeQuest waveform, but timing requirements are not met. Am I using tCO values for max/min delays in a wrong way or am I missing something else? Thanks
