10 years agoConstrainst for data launched by negative edge
Hi, What is the correct way to constrains source synchronous inputs in this case:External device provides clock with data. External device launches data on falling edge. FPGA latches dat...
10 years agoHello,
By using following, Timequest will consider that data is launched by falling edge. # Base clock create_clock -period "100MHz" -name CLK_IN [get_ports CLK_IN] # Virtual clock create_clock -name CLK_IN_VIRT -period "100MHz" set_input_delay -clock [get_clocks CLK_IN_VIRT ] -clock_fall -max $in_max_value [get_ports {DATA*}] set_input_delay -clock [get_clocks CLK_IN_VIRT ] -clock_fall -min $in_min_value [get_ports {DATA*}] changes compared to your constraints: I have removed -waveform option in create_clock for CLK_IN and have added -clock_fall in set_input_delay. i am not sure how should your design be properly constrained. Hence I would not be able to provide to the point answer. Sorry. There is one Application note (AN433 -Constraining and Analyzing Source-Synchronous Interfaces ). Just search on google and you will find it. It may be helpful. one question : Which clock have you been using to capture data? Are you using clock directly coming into FPGA? Thank you, Bhaumik
