IonHide's avatar
IonHide
2 years ago
Connection between two inout ports
Hello, I need to connect the 10 inout pins(A) to 10 inout pins (B) based on the logic of the cntrl signal (C) with respect to clock.
i-e when C = 0 , connect port A to port B &
when C= 1 , connect port B to port A.
what is the syntax I could follow to acheive the same , while simulating It not showing the results as needed.
Regards.
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    Nazrul Naim
    NazrulNaim_Intel
    Sorry for the delay. Regarding your issue, have you tried this coding before?
    // Declare registers for A, B, and control signals
    reg [9:0] A_out, B_out;
    reg A_en, B_en;
    reg [9:0] A, B;
    always @(posedge clk) begin
    if (C) begin
    // When C is high, transfer A to B
    B_out <= A; // Use non-blocking assignment
    A_en <= 0;
    B_en <= 1;
    end else begin
    // When C is low, transfer B to A
    A_out <= B; // Use non-blocking assignment
    A_en <= 1;
    B_en <= 0;
    end
    end
    // Drive A and B based on enable signals
    always @* begin
    if (A_en) begin
    A = A_out;
    end else begin
    A = 10'bz; // High impedance when not enabled
    end
    if (B_en) begin
    B = B_out;
    end else begin
    B = 10'bz; // High impedance when not enabled
    end
    end
    Hope that helps and do let me know if I can assist you further.
    Nazrul Naim
  • Farabi_Altera's avatar
    Farabi_Altera
    Do you have the verilog code? we can try to take look at it.
    regards,
    Farabi
    • IonHide's avatar
      IonHide
      if (C) begin
      B_out = A;
      A_en = 0;
      B_en = 1;
      end else begin
      A_out = B;
      A_en = 1;
      B_en = 0;
      end
      end
      assign A = A_en ? A_out : 10'bz;
      assign B = B_en ? B_out : 10'bz;
      where A, B are inout ports , C input signal& others are local registers.
      Regards.
      • FvM's avatar
        FvM
        doesn't look bad. Don't know which problem you experience. First output after direction signal change will be invalid due to registered x_en signal. E.g. C 1->0, A_ out latches old B output, then deactivate B and enables A. Unregistered x_en may achieve intended behaviour.
        If you don't get reasonable output at all, it's probably due to testbench design fault.
