IonHide
2 years agoConnection between two inout ports
Hello, I need to connect the 10 inout pins(A) to 10 inout pins (B) based on the logic of the cntrl signal (C) with respect to clock. i-e when C = 0 , connect port A to port B & when C= 1 , co...
Farabi_Altera
2 years agoHello,
Do you have the verilog code? we can try to take look at it.
regards,
Farabi
- IonHide2 years ago
always @(posedge clk) begin
if (C) begin
B_out = A;
A_en = 0;
B_en = 1;
end else begin
A_out = B;
A_en = 1;
B_en = 0;
end
end
assign A = A_en ? A_out : 10'bz;
assign B = B_en ? B_out : 10'bz;
where A, B are inout ports , C input signal& others are local registers.
Regards.
- FvM2 years ago
doesn't look bad. Don't know which problem you experience. First output after direction signal change will be invalid due to registered x_en signal. E.g. C 1->0, A_ out latches old B output, then deactivate B and enables A. Unregistered x_en may achieve intended behaviour.
If you don't get reasonable output at all, it's probably due to testbench design fault.
