Connecting a USB3.0 device to the USB Type-A port on DE-10 Standard
- 3 years ago
Hi all,
We have updated successfully to the 6.1.20 kernel (LTS), which resolves both the issue on the DE-10, as our own board. It did require some migration in our device tree, which took us some time.
Thomas
Hi Fakhurl,
Thank you, that was our expectation as well.
You state "While basic functionality will work". However, this is not the case. A USB3.0 device does not function at all. Not even at degraded performance. The device does not show up on `lsusb` either.
Even worse, after this, USB2.0 does not work either. With the same observation, no indication of any connected USB device within the system.
In the logs we only see the interrupt handler, after that, nothing.
To be able to use the USB again, we have to restart the device.
We have tried this with multiple USB devices.
Thomas
