14 years agoConfiguring clock domains with sdc files
Hello, For the past few days I have been trying to configure two different clock domains within my top level VHDL entity with no success. I have one base clock that I'm using to generate a...
14 years agoThe RTL viewer just shows what's in your code before optimization. The Technology Map Viewer is a better representation of what's real on the back-end and what you're timing against. That being said, you generally don't need get_nets at all, and get_pins can usually be avoided. I think you're going down the wrong path with those.
Can you describe how this second clock is created? Is it just a register clocked by clock_50_MHz whose output is used to drive the clock port of other registers? If so, try what I suggested and let us know the results.
