14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers.
The fpga clock is 48 MHz and serial clock for the ADC is 8 MHz. The VHDL code that I've written is given below.LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.NUMERIC_STD.all;
ENTITY SPI_MASTER IS
GENERIC
NUM : INTEGER := 24
PORT
CLK_IN : IN STD_LOGIC;
SPI_MASTER_SDIO : INOUT STD_LOGIC;
SPI_MASTER_CLK : OUT STD_LOGIC;
SPI_MASTER_CS : OUT STD_LOGIC;
ADC_DATA_IN : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END ENTITY;
ARCHITECTURE BEHAV OF SPI_MASTER IS
CONSTANT ADC_WRITE_REG : STD_LOGIC_VECTOR(12 DOWNTO 0) := '0' & x"008"; --WRITE REGISTER
CONSTANT ADC_DATA : STD_LOGIC_VECTOR(7 DOWNTO 0) := x"10"; --DATA TO WRITE
CONSTANT ADC_READ_REG : STD_LOGIC_VECTOR(12 DOWNTO 0) := '0' & x"015"; --READ REGISTER
SIGNAL DATA_TO_ADC : STD_LOGIC_VECTOR(NUM-1 DOWNTO 0) := '0' & "00" & ADC_WRITE_REG & ADC_DATA;
SIGNAL DATA_FROM_ADC : STD_LOGIC_VECTOR(15 DOWNTO 0) := '1' & "00" & ADC_READ_REG;
SIGNAL OE : STD_LOGIC := '1'; --OUTPUT ENABLE FROM FPGA, WHEN HIGH: SEND DATA TO ADC, WHEN LOW: RECEIVE DATA FROM ADC
SIGNAL DATA_IN : STD_LOGIC_VECTOR(7 DOWNTO 0) := "11111111";
SIGNAL MASTER_RST : STD_LOGIC := '0';
SIGNAL SENT : INTEGER := 0; --NUM BITS SENT
SIGNAL RCVD : INTEGER := 0; --NUM BITS RECEIVED
SIGNAL ADC_CLK : STD_LOGIC := '0'; --SERIAL CLOCK FOR ADC
SIGNAL COUNT : INTEGER := 0;
BEGIN
PROCESS(CLK_IN)
BEGIN
IF(RISING_EDGE(CLK_IN)) THEN
IF(COUNT = 2) THEN
ADC_CLK <= NOT ADC_CLK;
COUNT <= 0;
ELSE
COUNT <= COUNT + 1;
END IF;
END IF;
END PROCESS;
PROCESS(ADC_CLK,MASTER_RST,OE)
BEGIN
IF(FALLING_EDGE(ADC_CLK) AND MASTER_RST = '0') THEN
IF(OE = '1') THEN
IF(SENT < 23) THEN
--DATA_FROM_ADC <= DATA_FROM_ADC(14 DOWNTO 0) & '1';
DATA_TO_ADC <= DATA_TO_ADC(22 DOWNTO 0) & '1';
SENT <= SENT + 1;
ELSE
OE <= '0';
END IF;
END IF;
ELSIF(RISING_EDGE(ADC_CLK) AND MASTER_RST = '0') THEN
IF(OE = '0') THEN
DATA_IN <= DATA_IN(6 DOWNTO 0) & SPI_MASTER_SDIO;
RCVD <= RCVD + 1;
IF(RCVD > 6) THEN
MASTER_RST <= '1';
END IF;
END IF;
END IF;
END PROCESS;
--SPI_MASTER_SDIO <= DATA_FROM_ADC(15) WHEN OE = '1' ELSE 'Z';
SPI_MASTER_CS <= '0';
SPI_MASTER_CLK <= ADC_CLK;
ADC_DATA_IN <= DATA_IN;
SPI_MASTER_SDIO <= DATA_TO_ADC(23) WHEN OE = '1' ELSE 'Z';
END BEHAV; The parts that are commented are used for reading from the ADC registers. Also when reading the "IF (sent < 23)" is changed to "IF (sent < 15)". I used logic probes to see the output of the SCLK and SDIO pins (attached) and I don't see a problem. I am not sure why writing to the registers does not work. Here is the datasheet of the ADC since I couldn't upload the file: http://www.analog.com/static/imported-files/data_sheets/ad9649.pdf (http://www.analog.com/static/imported-files/data_sheets/ad9649.pdf) Any help/insight will be appreciated! Thanks.14 Replies
--- Quote Start --- Are you sending the right values for the W1/W0 fields? Cheers, Dave --- Quote End --- I think so. I want to write 1 byte of data, so W1/W0 is "00"
where ADC_DATA is declared as an 8-bit value.SIGNAL DATA_TO_ADC : STD_LOGIC_VECTOR(NUM-1 DOWNTO 0) := '0' & "00" & ADC_WRITE_REG & ADC_DATA; - Altera_Forum
--- Quote Start --- SPI CS is permanently tied low which is valid according to the datasheet. --- Quote End --- Ok. That fact was not mentioned in your post, so I wanted to check. --- Quote Start --- The only change between reading and writing is the number of bits sent to the ADC. The ADC is able to decode the address I send it, otherwise I would not read the correct values back. --- Quote End --- Are you sending the right values for the W1/W0 fields? Cheers, Dave - Altera_Forum
SPI CS is permanently tied low which is valid according to the datasheet. The only change between reading and writing is the number of bits sent to the ADC. The ADC is able to decode the address I send it, otherwise I would not read the correct values back.
Your waveforms do not show SPI CS#. Its important that your waveforms match the timing on page 24.
Cheers, Dave
